F2 prisms and batteries
de-1 dp-11 lr44
David
David
Hi
I have just received a really nice F2 in its original box. It came with a DP-11 prism and an unused, mint condition DE-1 as part of the deal. I guess the DE-1 was original to the camera body in the late 1970s and the owner decided to upgrade the meter to the DP-11 and store the DE-1? Should I keep the DE-1 because it is original to the camera, or sell this and keep the DP-11 to use with the F2? I understand that the DE-1 is the basic model but commands a good price as most were forgotten about in favour of more expensive prisms. I think the body is from 1977 (serial number is 7888xxx), so would this have shipped new with a DE-1 attached at that time?
Secondly, I have fitted two new LR44 batteires but the DP-11 meter needle continues to sit far right in the window and doesn't move at all. I don't get any movement when I look through the viewfinder and changes shutter speeds and f-stops either. Is the DP-11 broken? Am i using the wrong batteries? The camera and prism are not far from mint condition, so I am assuming both have had little use over the years.
  • 10,633 posts
Have you remembered to switch the meter on by moving the film-advance lever to the standoff position?
The DP-11 should have silver-oxide, not alkaline button cells. What you need in modern nomenclature are SR44 cells. I think they shipped with S76 cells originally. It should power up on new alkalines, but the meter will be erratic as the alkalines drop voltage as they are used.
David
David
Yes, I know about the red dot behind the advance lever. Thanks, I will order two SR44 cells. The finder itself looks to be in great condition, so I hope that will do it. What is your opinion on the DE-1 - keep or sell?
  • 10,633 posts
Try the DE-1 before you sell it. It is easier to focus with and brighter than the photomics as the prism is simpler as there is no need for the meter sensor. I usually had one around while I had my F2-s to use in the studio and other simple or controlled lighting.
