D750 not accepting SD card
d750 sd card
Finito Bennito
Finito Bennito
  • 4 posts
  • LocationNorth Georgia Mountains
Hello, All. I have a relatively new D750 and attempted to insert a new SanDisk SD card into Slot #1. The camera would not accept it. I then removed the existing card from Slot #2 and the camera would not accept it into Slot #1 either. The new card can be inserted into Slot #2 with no issues. It seems as though the problem is with the camera and not the card. Any suggestions that I can try out?
Thanks!
  • 7,802 posts
Use a strong light and inspect the condition of slot 1. Compare to how slot 2 looks, they should be identical.
Finito Bennito
Finito Bennito
  • 4 posts
I shall try this. The closest camera shop is about two hours away.
Thanks for your response!
  • 3,129 posts
Did you check that the cards are unlocked?
Also tagged with one or more of these keywords: d750, sd card
