D750 and SB-5000 wireless
sb-5000 wireless d750
IlMoro
IlMoro
  • 7 posts
Hi,
I cannot find any practical and updated info about someone who tested SB-5000 and D750, using the SB-5000 only as a wireless flash, detached from the camera.
Just found a video from 2016 (https://www.youtube....h?v=rLWmRfMycyw).
Hope Nikon solved the issue in the meantime.
Anyone knows anything about it?
  • 7,660 posts
As there is still no support for the WR-R10 as flash master on the D750, it will probably never work. The SB-5000 works well using AWL, though.
I got tired of waiting and got some Godox Ving speedlights instead.
  • 1,575 posts
Does radio control work with any Nikon bodies produced prior to the ones that were released at the same time as the SB-5000?
After using radio control I'll never go back to optical slaves.
IlMoro
IlMoro
  • 7 posts
I did not perfectly understand your phrase. Does it means I can use SB-5000 with my D750 in wireless mode through AWL?
I found this article and paragraph 1 says D750 is compatible with D750...but I´m a little bit confused: does it works or not?
https://www.nikonimg...1909&lang=en_GB
I also found this official compatibility article but do not know how to "read". It seems SB-5000 is fully compatible as remote for D750.
https://nikonsupport...312/SBCC_en.pdf
My simple question is: if I just buy one SB-5000, can I have it to work as remote flash with my D750 as is, without buying anything else?
Thanks in advance for any info.
  • 7,660 posts
It works using the IR link that uses the pop-up flash as a master. There is no radio link.
It is not as realiable or as easy to rig as a radio link as it is line-of-sight and the sun can drown out the signal sometimes.
If you want a radio link with the D750, why not look into the Godox system? You can get two V860II units and the transmitter for about 5000 SEK now as Photax are running a campaign. The SB-5000 is around 6500 SEK.
IlMoro
IlMoro
  • 7 posts
Many thanks for the answer, I missed some info.
I will have a look through the Godox system.
Also tagged with one or more of these keywords: sb-5000, wireless, d750
