upgrade to d800 from d610 and foucus issue
6 replies to this topic
jayrob84
jayrob84
  • 4 posts
hi guys im new here . i had a nikon d610 for christmas (used but good condition) and part of me wonders should i of spent a bit more and got a d800 or d810 . will i get a lot of benefit from that?
something im a little confused is i have a samsung nx3000 smart camera and it seems like the pics from that are sharper then the ones from my d610 with 50mm1.8g lens. tbh honest i expected a bit better quality from the nikon
  • 7,802 posts
What shutter speeds and what aperture do you use with the 50/1.8? Is the lens you have on the Samsung stabilized?
Could you post examples with the shooting data?
It should give acceptable results, even if it isn't one of the stellar Nikkors.
  • 1,601 posts
Peter is right. The D610 is capable of great results tho not is good as either the D800 or D810 because of the lower resolution sensor in the D610. That said, after looking at the nx3000 specs, I wouldn't expect to see a great deal of difference between it and the D610 because they have nearly the same size sensor. I didn't see any mention of either in body or on lens stabilization mentioned in the nx3000 specs.
jayrob84
jayrob84
  • 4 posts
samsung could be mate . ill take some tomorrow if i can and upload some. ive calibrated the lens and ti me the samsung is a little sharper
whats a stellar nikkor?
  • 7,802 posts
All the other AF-S f/1.8 Nikkors are among the best consumer grade primes they have made but the 50 isn't up to that standard, unfortunately. The old 6 element in 5 groups 50/1.8 in all its incarnations draws with a nicer character in the finished photo but the autofocus is noisy in the AF and AF D versions.
The only really excellent auto-focus normal from Nikon today is the 58/1.4.
If you can go with manual focus, the field gets bigger since all the fastish normals made after ~1972-1973 are excellent performers, even if the earliest need to be Ai-converted to use on an FX DSLR.
There are third-party normals that perform well and have a solid following, but I have never found one I liked.
My normal on the D700 has been either an AF-S 35/1,8, one of the old radio-active 35/1.4 manual lenses or my Ai'd 50/1.4 S•C from 1973 and the same goes for the D750.
jayrob84
jayrob84
  • 4 posts
could you put up some ebay links to the older lenses you where on about so i have a idea . will they work on my camera .
https://www.ebay.co....wAAOSwbLJeEga1
are these lenses any good ?
  • 7,802 posts
The one you linked to is Ai converted, so it will work.
It is a little soft compared to modern lenses, but the transition from sharp to unsharp is wonderful. It is a classic for street and PJ style environmental portraiture.
Lenses from before 1977 must be Ai converted to fit on your camera, but most are.
