Snapbridge no longer work with my Z7
snapbridge z7 iphone xs max bluetooth wi-fi
6 replies to this topic
fdormoy
fdormoy
  • 56 posts
  • LocationCanada, Quebec, Piedmont
When I got my Z7, I installed Snapbridge and it worked.  My Iphone is Xs Max model.  My firmware version is [C] 2.01 and [LF] 1.00 version.
But for reasons I do not know, it stopped working for several weeks.  When I opened Snapbridge I had message that there is a temporary problem with .... and we are addressing this problem (I do not recall exactly the message  because I dont see anymore this message since I desinstalled and re-installed the app.
When I try to connect Bluetooth, it says failure to connect please try again
When I start pairing, The app tries to connect to the camera but after a while it says Connection failure, make suere the camera is ON and within reach (which of course was the case).
Can someone help me, because I wanted to pair so as to geotag my photos and I cant do it.
Thanks in advance
  • 10,649 posts
What version of iOS are you using? If you have upgraded to 13, that probably is your problem.
https://www.nikonimg...ed=1&lang=en_US
chutch15
chutch15
Any news on a Snap Bridge fix for iOS 13?
fdormoy
fdormoy
  • 56 posts
I have IOS 12.4.1
fdormoy
fdormoy
  • 56 posts
So if it seems that the IOS version 12.4.1 is not a problem, what could it be ?
I repeat.  I cant connnect my Z7 to snapbridge.  Snapbridges sees that I have the NZ7 but the pairing is always a failure.
onetyonepilot
onetyonepilot
Even I am having connection problems with my D5600. It used to work perfectly with snapbridge. But now the camera WiFi is not turning on and I'm getting the message "unable to connect" on the camera. Bluetooth is also not detectable by any mobile device. I think the problem lies within the camera. Did you try to enable the camera WiFi? And is it turning on?
fdormoy
fdormoy
  • 56 posts
When connecting through wifi, it works, although I still cannot benefit from GPS localisation to be saved in the metadata of the photo.
So does it mean that it will no longer be possible to benefit from bluetooth connection with Snapbridge ?  That is a pity because using wifi is more energy consuming than using bluetooth.
Also tagged with one or more of these keywords: snapbridge, z7, iphone xs max, bluetooth, wi-fi
