Milky Way and Night Photography
aperture exposure
Saffa Ben
Saffa Ben
I would like to try to take some night photography - specifically the milky way.  I do not want star trails, so am limited by the Rule of 500.  I have two lenses.  A Nikon 35mm f1.8 and a Nikon 10-24mm f3.5-4.5, and am shooting with a Nikon D7000.
Using the rule of 500 and the 1.5 crop factor, I know that the max exposure time I have before I get a star trail is about 9 seconds for the 35mm lens and about 33 seconds for the 10-24mm lens.
What I would really like to know is, is there a graph / chart that I can use to compare or tell me how much light would enter the lens, over the different exposure times, so that I would know what lens would be best to use?  Or put another way - would more light enter the 35mm lens at f1.8 over 9 seconds, than would enter the 10-24mm lens at f3.5 over 33 seconds?
I'm going to test both - anyway - but it would be nice to know.
Any advice appreciated.
  • 7,516 posts
f/1.8 is 1/3 of a step faster than f/2 and f/3.5 is 1/3 of a step faster than f/4. This means that the difference in light transmission is 2 stops. The 9 second f/1.8 exposure is thus equal to a 36 second exposure @f/3.5. I think that the difference in field of view between the lenses is more important than the difference in light gathering as you want the widest view you can get.
Saffa Ben
Saffa Ben
Many thanks.  I'll certainly test both.  Agree as well about the field of view - wider angle will give broader night sky view.
emilyanderson
emilyanderson
  • 12 posts
Use a camera that can shoot a decent image at 1600 or 3200 ISO is a wise choice.  Consuming the same 24mm lens on a Nikon crop, you'd end up with an effective focal length of 36mm (24×1.5 = 36). Applying the 500 rule will yield a shutter speed of 13 sec. (500/36 = 13.89).
You should work with a lens with a maximum aperture of at least f/2.8; the faster the higher. It’s not that you’re totally out of luck if your fastest lens is f/3.5 or you’ll have more of a challenge on your fingers since the lens won’t be able to gather as far as light.  :)  :)
