I'm pretty much still a beginner with my D5600 that I got around 8 months ago. In the past, I've used Windows 7, a compact Nikon camera L610, and an old Nikon program to edit ... Nikon View, I think.
I've recently upgraded to a new laptop with Windows 10, and just downloaded NX-i and Capture. I've not done much with Capture or raw conversions yet, but I just edited some JPEG shots with NX-i, and am running into a weird problem.
When I save my changes to the new image that I rename, so it's alongside the original in the folder, and then view the images in my normal Windows viewer, it does not show the changes. The original and edited versions are the same. If I try to pull the image up in Windows Paint program, same thing. If I pull it back up in NX-i, the changes are there and saved, but no where else. I've tried saving it both ways, with the 2 icons in the lower right corner, and still the same issue.
I'm still new to Windows 10 too, so maybe there's something I don't have enabled. Also, NX-i seems to add some oddly labeled new folders to my existing folder that I'm not sure about. I haven't read the full 400 pg. manual yet, and maybe that's the problem. Tech Support is closed today so I thought I'd check here to see if anyone is familiar with this issue.
Thanks in advance.
