Difference between D and G
7 replies to this topic
sunshine
sunshine
  • 292 posts
  • LocationVirginia
I have been looking at used 300mm f/2.8 primes. I know some of the basic differences between D and G lenses, but I am curious about functional usability or image quality differences that may not be described in the technical documents.
There's an AF-S 300mm f/2.8 D with a serial number in the 204xxx range and an AF-S 300mm f/2.8 G VR with a serial number in the 304xxx range. Both are advertised at good prices, but the difference between them is $1,000 USD. If I purchase one I'd be using it with either a D500, D750, or D810.
I'm not concerned about the lack of VR on the D model. Would I see a visible difference in image quality? If something went wrong with the D will Nikon still fix it? Any other advice you lens experts can offer that would sway me toward one or the other? If the D would give me near equivalent IQ and can still be serviced, I could sure use that extra $1k somewhere else.
Thanks!
Any G lens is a D lens. Not all D lenses are G lenses. The difference is that
a G lens lacks an aperture ring for manually setting the aperture on the lens
(rather than the camera). ... The D lenses are older lenses.
I never use VR myself.
If you can, the D810 is just plain crazy… still part of my arsenal!
  • 10,646 posts
Is it the original D or revision II? The AF is faster in rev. II, and the lens foot is much better even if none of the 300/2.8 lenses have a really good foot. The G version is nanocoated unlike the earlier versions, which raised the performance when shooting against the light or with pin-point light sources in the frame.
The D lenses are getting old, rev. I before Feb. 2001 and rev. II before Sept. 2004. I am not sure if Nikon still have parts for them.
sunshine
sunshine
  • 292 posts
  • LocationVirginia
Here's a link to the listing if you're interested.
Sold: NIKON AF-S 300mm f2.8 D LENS - FM Forums
I've found a site that shows serial number ranges with years of manufacture but can't tell if this particular lens is a I or II. The number is close to the middle of the range.  Focus speed is a priority. Any idea how it might compare to a 3rd party lens like the Tamron 150-600 v2?
For D lenses with an aperture ring, is the ring the only way to set aperture or can the setting also be changed electronically using the camera dial?
  • 10,646 posts
This is the first version. I think the AF is faster than the consumer zooms even if it is slower than in later models.
When you set the aperture ring to the smallest aperture on a D or early AF lens, the ring can be locked and hte aperture controlled from the body.
sunshine
sunshine
  • 292 posts
  • LocationVirginia
Thanks! I spoke to the seller last night and decided to go ahead with the purchase. He confirmed that the aperture can be controlled from the body. I'll post some photos when I receive it.
  • 1,098 posts
cool and post some pictures too. so  we can see how lens turns out. some might want to see if worth the price to buy or not.
sunshine
sunshine
  • 292 posts
  • LocationVirginia
Lens arrived early this week but I was away for my day job most of the week. I got outside with it today for a couple of hours. Here are a few sample shots from both the D810 and D500. All shot at f/2.8.
D500:
D810:
