Does the Rokinon 14mm lens work on a Nikon D3200?
nikon lenses rokinon wide angle fisheye 14mm astrophotography astro dx fx
Juicy Miggler
Juicy Miggler
So this is my first post and I'm not sure if I'm doing this correctly, but I have a question. Can I use a Rokinon 14mm f2.8 lens with an AE Chip with a Nikon D3200 camera body? Thank you!
Fletch
Fletch
  • 395 posts
  • LocationHawaii
Rokinon 14mm f/2.8 IF ED UMC Lens For Nikon with AE FE14MAF-N
The 14mm f/2.8 IF ED UMC Lens for Nikon with AE Chip from Rokinon gives you approximately a 115° view with dramatic results when used with a full frame digital camera or 35mm film camera. It includes a special chip that allows the lens to work with the camera's focus confirm, auto exposure, auto metering and auto white balance functions. With hybrid aspherical lenses, you will produce sharply defined images with a minimum of distortion and chromatic aberrations. This manual focus 14mm lens focuses as close as 0.9' / 28cm from the lens, and has a built-in petal-type lens hood. With some cameras, Shutter Lock must be disengaged on the camera's menu.
Special chip allows the use of camera's focus confirm, auto exposure, auto metering, auto white balance Ultra wide-angle 14mm lens with an approximately 90° angle of view using an APS-C camera, for dramatic effects Lens is constructed with two ED lens elements, one hybrid aspherical lens element and one glass aspherical lens element, for outstanding, sharply defined images Minimal distortion and chromatic aberrations Super multi-layer coating to reduce flares and ghost images Lens has a minimum focusing distance of 0.9' / 28cm for enhanced close-up shots Also conforms to APS-C (1:1.5x) size digital imaging format Lens includes a built-in petal-type lens hood
  • 6,946 posts
Yes, you can. The older, non-chipped lens can be used as well, but without the light-meter.
Also tagged with one or more of these keywords: nikon, lenses, rokinon, wide angle, fisheye, 14mm, astrophotography, astro, dx, fx
