D5300 shutter release issue using AF Nikkor 28-70mm 3.5-4.5 D lens
d5300 af nikkor 28-70mm shutter release
marktb
marktb
When the lens is attached a message appears "lock lens aperature ring at minimum aperature". When I do lock the aperature at the minimum setting the message goes away and the shutter-release button works. If I try any other aperature setting I get the message again and the shutter release button does not work. From what I've read about this lens the autofocus will not work on this camera body but everything else should.
  • 10,643 posts
You need to lock the aperture ring and then control the aperture from the body. If the ring isn't set to its smallest aperture, you won't have the full range available in S or P modes as the ring blocks the mechanism.
Also tagged with one or more of these keywords: d5300, af nikkor 28-70mm, shutter release
