Friends and the Profoto B10
9 replies to this topic
TheGlobalCitizen
TheGlobalCitizen
  • 57 posts
  • LocationColorado
Just getting some practice with friends
TheGlobalCitizen
TheGlobalCitizen
  • 57 posts
  • LocationColorado
This was done with a friend two days ago :)
  • 1,896 posts
Any given type of soft box will have the same angle of projection.
The only difference between a small and large SB is the wrap when
a large one is brought closer.
May I suggest you take your little SB much closer — this will require
less power btw.
TheGlobalCitizen
TheGlobalCitizen
  • 57 posts
  • LocationColorado
Was at local college art instillation and took some quick snaps
  • 1,896 posts
The first of the last two is very successful. :P
TheGlobalCitizen
TheGlobalCitizen
  • 57 posts
  • LocationColorado
So a month and a half ago I bought the B2 w 2 Heads for $999 from B&H and have been using it in conjunction with my B10... still need some practice but I am having tons of fun
  • 1,896 posts
Yep, got the B2 too… great tool!
I would not ignore the inherent DR of a scene but exploit it.
May I suggest…
TheGlobalCitizen
TheGlobalCitizen
  • 57 posts
  • LocationColorado
Another one
  • 1,896 posts
Ok, if you want to go the chiaroscuro way (which is a very cool way to do it),
it is like the left side of this frame. Contrary to stage
light (another approach
that would use way more contrast), this scene seams to be sitting between
the two but taking advantage of none.
TheGlobalCitizen
TheGlobalCitizen
  • 57 posts
  • LocationColorado
This was done a couple days ago
