ISO is a fake standard in cameras
6 replies to this topic
mikew
mikew
  • 798 posts
  • LocationNorth East Lincs
I understood totally the ISO invariance thing but chose to ignore it as i like to chimp my images, what surprised me was the inconsistency of the ISO values between different manufacturers, we know now why one ISO 100 is better than another.
https://www.youtube....1&v=QVuI89YWAsw
It is NOT A FAKE but it is of as little interest as the rest of the exif
information nowadays.
Anyone beginning may need the triangle's reference values but it
is getting the more relative as the mastery kicks in until it ends up
totally useless.
Improvements in terms of DR and low lights recording are some of
the reasons behind the recent appreciation.
ETTR was THE thing 20 years ago and I have been teaching for so
many years that the ETTL approach is better when considering that
one should protect the whites at ALL costs.
mikew
mikew
  • 798 posts
totally useless.
I took the main thrust of the video to be saying because different manufacturers assigned different amounts of gain to given iso values it made the values pointless when comparing one make/model to another.
If i was looking to upgrade a camera body one aspect i may look at is how the sensor handles noise at a given iso, now if camera A gives certain results at iso 3200 and i see camera tests and forum posted images from camera B that match it for noise but at 6400 then i may be tempted to buy B.
He was saying if you stop talking iso and use gain from the sensor's base iso  the fudging of facts may not be as easy to hide, it only makes sense if you accept the light sensitivity of a sensor never changes, the increase only comes from manipulation of the original exposure.
I do agree with you about the exposure bias and trying to protect whites.
I took the main thrust of the video …
Even in film time 35mm, 120, 220 and 4X5 film was bought in
large quantities to make sure that each format shared the same
batch production number — when tested to establish the "real"
ASA value, I was sure then that the whole lots had the same.
Then, since the emulsions were made to given specifications, it
was important to know the ASA.
This subject is worth more discussion than I am patient to type.
Have a good one, Mike… maybe later. :P
  • 648 posts
One thing Tony doesn't mention is the lenses used, and it appears they we're all different. Some lenses transmit more light than others and can be 1/3 to a half stop or more different.
TheGlobalCitizen
TheGlobalCitizen
  • 59 posts
  • LocationColorado
Here is Lee Morris of FStoppers responding to Tony's claims
https://www.youtube....h?v=EvJ-H_xl3zE
What Lee Morris is seeing are in the first case a metering bias to protect the highlights in modern bodies and in the second a result of the analog gain that is used to boost the signal before the A/D converter. This will change the S/N ratio compared to boosting the already converted raw file.
