D7500 Top LCD won't go off
d7500 lcd
patriciomurphy
patriciomurphy
Hi everybody, first post.
While going nuts trying to make SnapBridge work with my D7500, I found another issue that worries me more: the top LCD won't go off unless I take the battery out.
Someone had this problem? It's sucking the battery. Tried a full reset, but the camera stays with the "resetting..." text forever and when I finally take the battery out, place it again and power on the camera, all my settings are still there.
Any idea on what's going on?
Thanks!
Fletch
Fletch
  • 404 posts
  • LocationHawaii
https://www.nikonimg...me?configured=1
You're not the first one to report that and the last time no one had an answer for the problem either.
Tom_T
Tom_T
Thanks!
Interested to know if you solved your problem yet
patriciomurphy
patriciomurphy
No, talked to the dealer. I'm past the return point, but after a couple of jobs the camera will go to service. If they can fix it, OK, if they don't then they'll have to replace the camera.
What i'm doing as a workaround for the battery drain problem is taking the battery out after powering down, then the Top Panel goes off and everything is, say, normal.
I still can't use SnapBridge, but I wouldn't trust it anyway for serious work, so for now I'm pretending I have a camera that doesn't have wi-fi...
patriciomurphy
patriciomurphy
Just an update. Camera finally went to service, I'll update the thread as soon as I get it back with info on either the connectivity problem is solved or not.
Also tagged with one or more of these keywords: d7500, lcd
