I got an Nikon D90 DSLR with a problem
dslr problems
17 replies to this topic
locrasm999
locrasm999
  • 7 posts
So my uncle's camera got stuck in our dressing for almost 8 years but luckily its working. But my problem is this, Wherever i take a picture that has light there is some color distortion in the image. Come somebody help me fixing this?
  • 810 posts
Heigh years…?
Plenty of time to spoil both the lens or the sensor.
Check if both are clear of anything like fungi!
  • 6,845 posts
Could you show us a sample image?
locrasm999
locrasm999
  • 7 posts
This is the sample images any way to fix this problem?
  • 810 posts
OK, this is out of anything I have experienced
or have seen… I am clueless!
First thing I would suggest is to reinstall the firmware.
locrasm999
locrasm999
  • 7 posts
I did update the firmware, i think it wont solve the problem.
  • 6,845 posts
I have never seen anything like this either... Have you checked that the lens and sensor are clean? Don't forget to open the aperture so you can see inside the lens. If that is the case, try another memory card and format it in the camera.
  • 810 posts
Right, I am sure it has nothing to do with the lens
…but still clueless, sorry!
locrasm999
locrasm999
  • 7 posts
Im inexperience on doing such cleaning or checking things on my lens. Can someone guide me?
And there's no tech support or stores nearby to check what's the problem.
Fletch
Fletch
  • 236 posts
  • LocationHawaii
Whats your White Balance set to?
As to cleaning if you don't know what you're doing its better to find someone that does.
https://www.nikonimg...ed=1&lang=en_GB
https://www.youtube....h?v=jcSnX3ZJNOc
A Step-by-Step Guide to Cleaning Your Camera Sensor
locrasm999
locrasm999
  • 7 posts
I set it to auto i think. I am charging my battery rn so that i can.
locrasm999
locrasm999
  • 7 posts
Any way fix to this right now?
Fletch
Fletch
  • 236 posts
  • LocationHawaii
Not that I can think of sorry, its to bad there is no camera repair in your local area.  Is there at least a camera sales store maybe they can at least give you some advice.
  • 1,403 posts
What computer software did you use to process this image?
locrasm999
locrasm999
  • 7 posts
Well sadly, there is no camera stores nearby that's why i need help about questioning my problem in this forums  :)
Dont get you there ron. This image is never been process by a software. Well its raw never been touched
I just remembered something my brother take the camera to abroad. He said that he want the camera lens clean because there is some dust inside. Maybe theres a problem there?
Fletch
Fletch
  • 236 posts
  • LocationHawaii
SERVICE AND SUPPORT - Nikon Asia
#17
  • 1,403 posts
Dont get you there ron. This image is never been process by a software. Well its raw never been touched?
Well, you had to download the image to something before uploading it here. It's not a direct post straight from the camera, is it? I'm not suggesting that you processed the image in any way but, sometimes, software can introduce artifacts of their own. Otherwise, I'm with the others and don't have a clue.
#18
  • 1,173 posts
Also never seen something like this, so only guessing.
Have you done a full reset to default values (factory reset) of the camera? If not, this is where I would start with
Resetting Nikon D90 DSLR Camera
While this describes the two button reset, there is also the possibility to do a factory reset using the menu.
Could you take the same picture using RAW and see what it gives?
Beyond possible technical problems, what I find strange is how the light contours are next to the pole. It could be the sensor, but it could also be the compression to JPG.
Another possibility could be the battery, no longer delivering the power that the sensor needs to operate properly. What does the meter on the LCD screen says for freshly charged battery?
From previous messages I do understand that this picture has been copied directly from the SD card? No software in the middle?
As I said in the beginning of this post: I am guessing ...
Also tagged with one or more of these keywords: dslr, problems
