Hello,
How can I see the Shutter counts on my D70S?
Thanks
The shutter count is stored in the exif data of every image the camera takes. You can use a program such as exiftool to check, or use an online utility such as this one:
Check Camera Shutter Count and Manufacture Date
Its a long time since i had my D70 but i have a feeling it may reset itself after 9999
Yes, the number of each frame can't be higher than 9999
but the sequence number is kept in the metadata, Mike.
Did say it was a long time ago
The shuttercount is hidden in the maker notes that few applications used to read. This has changed relatively recently. It used to be that exiftool and PS were the only widespread apps that read the full EXIF.
