Problem setting the Histogram for the D5600
histogram display playback
Hebephrene
Hebephrene
  • 5 posts
Hey One & All
           Working my way through the D5600. In the playback menu I can get to the Playback Display Options and I can click and get a check mark in the RGB HIstogram box. But there is no "done" option, so while I hit "Ok" the setting doesn't take. I thought perhaps this was because I was shooting RAW so I reset for normal JPEG but still no luck. Thanks
  • 10,643 posts
If the D5600 works anything like older Nikons, the Playback display options menu lets you select what options are available for playback. You then scroll through the different screens by pressing the multiselector up or down while in playback mode.
Hebephrene
Hebephrene
  • 5 posts
Yes, that is correct. And I can navigate place a check mark in the box next to the Histogram choice, or any of the other boxes, None, Overview etc, but unlike the tutorials I have seen there is no "Done" to be clicked for the camera to accept the changes. Once the screen gave me the option to save changes but I can no longer do that. My only options are right click on the OK dial or OK and neither provides the change to Playback Display options. Thanks
  • 10,643 posts
If you read the reference manual, page 221, pressing OK should save the settings and return to the menu level above.
Also tagged with one or more of these keywords: histogram, display, playback
