Slave units don't synchronize with D5200
slave flash
OBSIDIANA
OBSIDIANA
  • LocationMexico
Hello,
I'm trying to trigger some slave units to the attached strobe on my camera, but apparently the don't synchronize correctly, they discharge, but their light does not affect image.
I have the following setup:
  • D5200
  • MASTER FLASH: VIVITAR DF-3000 (dedicated TTL)
  • SLAVE UNIT: TUMAX 160S (generic) slave unit
I have configured my camera in the MANUAL setting, at various power levels, but none of them gives the required result.
I have also shot at various lens openings with the same results.
I also varied shutter speed, and aout 3 sec., the slave light gets into the image (that is: there is a 3 sec. delay?
Please, can someone gime me some advice?
Thanks in advance for your valuable help
Fletch
Fletch
  • 302 posts
  • LocationHawaii
The Vivitar appears to be a slave only from what I read on B&H in the product description, the Tumax I can't see any reference to it being able to slave or master.
OBSIDIANA
OBSIDIANA
  • LocationMexico
Vivitar CAN be a SLAVE, but it is used as MASTER.
the TUMAX can also be a MASTER or a SLAVE, in this case, it is performing as SLAVE.
I have made tests with my beloved D3100 and the set works just fine, so, I believe there is something I'm not considering with D5200
Also tagged with one or more of these keywords: slave, flash
