I wanted to post this problem in case someone else starts having the same issues with the Nikon D850 not firing.
I purchased the D850 in April, 2018. Ever since I've owned it, it has a problem with not firing once in a while, maybe 1 out of every 80 shots. I have it set to fire when the camera is in focus and when it is not in focus. If I'm doing headshots, I'll be photographing a person using a PocketWizard on my hot shoe to fire the flash. As I keep taking one photo after another with about 5-10 seconds in between shots, there will inevitably be one shot that won't fire even though I pressed the shutter button. But the problem is so intermittent that it is difficult to troubleshoot. The problem isn't just limited to headshots using a flash, it also happens when I am out capturing a nature scene without flash.
Please note that I use the AF-ON button on the back of the camera to focus on my subject and don't use the shutter button to focus.
When the problem just happened yesterday, I had taken 69 photos with some blurred intentionally and others in focus and on the 70th shot, while keeping the subject in focus, it wouldn't fire while I was pressing the shutter button. And after I released the shutter button, it fired 2 seconds later even though all the other shots before that shot and after that shot fired right away when I pressed the shutter button.
The problem still happens when I use different memory cards such as the Lexar SD 32GB 600x card or the Sony XQD R:400mb/s W:400mb/s 32GB card.
Does anyone have any idea for a solution before I send it in to Nikon Professional Services for warranty repair? Thanks.
