Remote shutter release
remote shutter release
9 replies to this topic
Mustang100
Mustang100
  • 5 posts
Hi there....I tried to use a remote shutter release the other day and could not get it to work.  Could it be because my Nikon is set to Back button focus? And if it is ...is there anyway to get BBF to work  with the remote shutter release?
  • 10,635 posts
What body, what shutter release? Have you tried cleaning the contacts? The focusing mode should not matter, even if the release mode can lock things up on some bodies. Release priority is safer with a remote release.
It should work even in BBF… just prefocus and then
switch off the AF making sure the subject nor the ca-
mera will move at all… otherwise, OoF guarantied!
Mustang100
Mustang100
  • 5 posts
HI ... D7200 ...remote shutter is new generic mc/dc2. The remote works on the Nikon 3300 ....which does not have BBF Focus enabled.
Hi ...probably a stupid question ..but when you say ''switch of the AF"... you mean switching the lens to MF?
  • 10,635 posts
Do you use AF-S or AF-C?
In single-shot AF, the default is focus priority. This means that the shutter won't fire unless the AF has acquired focus. In the continuous focus mode, the default is release priority where the shutter will fire without having acquired focus.
One of the nice things with using BBF is that you can safely leave the camera in AF-C as you can release the focus button whenever you like and the AF turns off.
Yup! :P
Mustang100
Mustang100
  • 5 posts
HI ..its set to AFC - CH
Yup! :P
I have switched the lens and the D7200 to MF - separately and together and the remote will still not work :(
  • 10,635 posts
Sounds like there is something up with the tolerances in the contact on either camera or remote. Can you borrow another remote from somebody?
+1
… maybe not a third party unit!
Mustang100
Mustang100
  • 5 posts
I tried with my Neewer wireless remote and selected the Remote Control ML-L3 Mode in the photo shooting options - and that now works perfect .... The remote cable worked on my D3300 but still not able to get it working the D7200 - will buy a new one and try it again
Also tagged with one or more of these keywords: remote shutter release
