Building a Telecaster from a kit.
18 replies to this topic
The headstock blank with the outline in pencil.
29703455927_b1feabf5cc_o.jpgPES_2018-09-12_20-54-10_24mm_ by merco_61, on Flickr
The body with the non-standard holes for the supplied pickguard plugged.
44105688594_6c616950f9_o.jpgPES_2018-09-15_14-19-07_24mm_ by merco_61, on Flickr
The headstock roughly shaped and the fretboard taped off for protection.
29888865137_496ab516e5_o.jpgPES_2018-09-15_14-20-09_24mm_ by merco_61, on Flickr
...and from the back.
43915343415_5b080cf649_o.jpgPES_2018-09-15_14-20-27_24mm_ by merco_61, on Flickr
The heel of the neck.
43014905300_1086d52d8c_o.jpgPES_2018-09-15_14-20-41_24mm_ by merco_61, on Flickr
The better pickguard that will replace the kit supplied one.
43014903680_796d419210_o.jpgPES_2018-09-15_14-21-48_24mm_ by merco_61, on Flickr
The body with the hole plugs cut down.
30954154998_d3366b25e0_o.jpgPES_2018-09-15_14-40-20_24mm_ by merco_61, on Flickr
I have some great whiskeys, a Strat and some
cool amps should you be in the vicinity! :P
Your Build Peter?  Keep the thread updated as you move through it!
It doesn't change much as I am in the phase when I sand everything down, wet the surface to raise the fibres and then sand it with the same grit, followed by the same procedure with a finer grit. I am finished with the 320 grit now and it is time for the really timeconsuming 600 grit finish sanding with two wetting stages. Then comes the Tru-Oil with two treatments per day with a cutting stage with steel wool to start each day. There will be more photos when I have finished the sanding, and then more again after the first oil treatment.
I have some better pickups than what came in the kit on order, and some upgraded electronics as well.
nbanjogal
nbanjogal
  • 2,094 posts
  • LocationUT, USA
I can't wait to see the finished product, but I'm truly enjoying seeing your work in progress. I love seeing the texture in the wood and that fine dust from the sanding. What's your lighting setup for this? The light and shadow are so rich...
This is another one I wish I could see video of! All that sanding sounds like a lot of work, but it seems like it could be very meditative... So what are you listening to as you work? And what will be the first song you play when it's done?  :D
The lighting is similar to what I used for the headstock blank in the Your best... challenge the week ending September 16, a fluorescent household bulb camera left and halogen camera right.
I mostly listen to Mary Spender and Sarah Longfield as I work, their laid back fingerpicking style is such a nice background.
As to what to play first, I am so rusty that I will probably just start with an open G and improvise from there to get the fingers used to playing again.
Sanding the guitar parts is finally over.
43267301500_cbdf471c14_o.jpgPES_2018-10-03_15-25-58_35mm_ by merco_61, on Flickr
31207419318_567ec31601_o.jpgPES_2018-10-03_15-26-23_35mm_ by merco_61, on Flickr
43267298400_224c83c795_o.jpgPES_2018-10-03_15-26-41_35mm_A by merco_61, on Flickr
31207417838_98290b3a2f_o.jpgPES_2018-10-03_15-27-29_35mm_ by merco_61, on Flickr
43267292920_4b4c578d29_o.jpgPES_2018-10-03_15-28-08_35mm_ by merco_61, on Flickr
31207414878_16def6cc61_o.jpgPES_2018-10-03_15-28-32_35mm_ by merco_61, on Flickr
31207412368_1fb98993c5_o.jpgPES_2018-10-03_15-28-40_35mm_ by merco_61, on Flickr
31207410558_d4ba47e7c5_o.jpgPES_2018-10-03_15-28-48_35mm_ by merco_61, on Flickr
45080324621_730524f922_o.jpgPES_2018-10-03_15-29-06_35mm_ by merco_61, on Flickr
Time for the Tru-Oil. One application per day for the next 10-20 days or so.
31207407448_c2cbdc8ae1_o.jpgPES_2018-10-03_15-30-03_35mm_ by merco_61, on Flickr
I will try to remember to take photos of the parts tomorrow, before the fifth layer of Tru-Oil goes on.
The neck isn't this dark, I have just given it a low exposure to enhance the grain in the maple.
45136274592_45504289fa_o.jpgPES_2018-10-08_16-48-29_35mm_ by merco_61, on Flickr
The fretboard is taped off as I will use some Ernie Ball Citrus oil or equivalent on the heavily roasted maple fretboard when the rest of the neck is finished.
31311383298_4fb8de0538_o.jpgPES_2018-10-08_16-49-18_35mm_ by merco_61, on Flickr
44274543475_0eae5ceedd_o.jpgPES_2018-10-08_16-50-18_35mm_ by merco_61, on Flickr
31311379018_9bcd13a69b_o.jpgPES_2018-10-08_16-51-56_35mm_ by merco_61, on Flickr
45136271652_6578ab59ae_o.jpgPES_2018-10-08_16-52-11_35mm_ by merco_61, on Flickr
44274529355_d3e56dc488_o.jpgPES_2018-10-08_16-52-33_35mm_ by merco_61, on Flickr
45136252362_7c54bb7e47_o.jpgPES_2018-10-08_16-53-00_35mm_ by merco_61, on Flickr
31311350398_8afed00b62_o.jpgPES_2018-10-08_16-53-24_35mm_ by merco_61, on Flickr
44463053024_6498f3de9b_o.jpgPES_2018-10-08_16-53-36_35mm_ by merco_61, on Flickr
44463049744_a6229b5cd3_o.jpgPES_2018-10-08_16-54-03_35mm_ by merco_61, on Flickr
44274503745_ca53dcbb7b_o.jpgPES_2018-10-08_16-55-04_35mm_A by merco_61, on Flickr
nbanjogal
nbanjogal
  • 2,094 posts
  • LocationUT, USA
I love those closeups of the grain and sheen from the oil. Really cool to see this coming together.
Tony
Tony
  • 2,520 posts
  • LocationBeaverton, Oregon
Agreed Nicole.  A very labor intense project, however when we view the finished product, we will all be dazzled.  Thanks very much for the treat, Peter.
TT
The electronics as supplied in the kit. Flimsy components, badly soldered with quick-connects that I don't trust for the pickups.
31437803018_0b027a3a62_o.jpgPES_2018-10-14_13-53-34_35mm_ by merco_61, on Flickr
The new switch, pots and output jack.
43496493860_f6467719e3_o.jpgPES_2018-10-14_13-54-27_35mm_ by merco_61, on Flickr
The supplied pots have a mounting post that is only 6.84 mm.
31437795818_957a4ab83a_o.jpgPES_2018-10-14_13-55-24_35mm_ by merco_61, on Flickr
The DiMarzio ones are 9.41.
30372648237_62138c86d3_o.jpgPES_2018-10-14_13-55-46_35mm_ by merco_61, on Flickr
The mounting plate.
43496481030_5cebb682da_o.jpgPES_2018-10-14_13-59-06_35mm_ by merco_61, on Flickr
The holes are 9.25 mm.
43496477270_b0e5de1a0d_o.jpgPES_2018-10-14_14-00-04_35mm_ by merco_61, on Flickr
A sharp 9.5 mm drill bit in my drill press soon solved this.
45311656281_56324f02e5_o.jpgPES_2018-10-14_14-10-56_35mm_A by merco_61, on Flickr
31437781678_1db121e74a_o.jpgPES_2018-10-14_14-11-06_35mm_A by merco_61, on Flickr
Some deburring to finish it off.
31437778478_3f7691a0b7_o.jpgPES_2018-10-14_14-14-24_35mm_A by merco_61, on Flickr
The parts fitted.
30372627807_3a47b088f3_o.jpgPES_2018-10-14_14-21-13_35mm_ by merco_61, on Flickr
45263300732_e3312e13d4_o.jpgPES_2018-10-14_14-21-27_35mm_ by merco_61, on Flickr
Soldering things together will be done after the body is finished as I want to connect the pickups at the same time.
Here is how things look after 9 layers of Tru-Oil.
43707807580_c53d4f39cd_o.jpgPES_2018-10-23_15-47-33_35mm_ by merco_61, on Flickr
43707805230_aed3a25035_o.jpgPES_2018-10-23_15-47-47_35mm_ by merco_61, on Flickr
45474536522_dd4ac5b87b_o.jpgPES_2018-10-23_15-48-37_35mm_ by merco_61, on Flickr
31652707158_79d2cc83f4_o.jpgPES_2018-10-23_15-49-04_35mm_ by merco_61, on Flickr
... and the surface knocked down with 0000 steel wool to prepare for the tenth layer.
44799636984_b2fc1b34f1_o.jpgPES_2018-10-23_16-03-26_35mm_ by merco_61, on Flickr
43707795190_7dda94f096_o.jpgPES_2018-10-23_16-04-03_35mm_ by merco_61, on Flickr
The neck is finished after 10 layers and will be put aside to stabilize until the final wet-sanding, rubbing, swirl-removal and waxing. The body needs more oil layers as the basswood is more porous than maple. It will probably be finished in a week or so, and will then have to stabilize for a week until I can finish the oil finish and start assembly.
…and a fair amount of elbow grease! :P
Ready for wet sanding, buffing and wax.
43999315680_09253aba98_o.jpgPES_2018-11-10_09-07-50_24mm_ by merco_61, on Flickr
43999314230_246ac570b5_o.jpgPES_2018-11-10_09-08-13_24mm_ by merco_61, on Flickr
Buffed.
43999313200_f7a3f8e7e9_o.jpgPES_2018-11-10_10-16-43_24mm_ by merco_61, on Flickr
The waxed surface waiting for final polish.
31945082898_5f92601157_o.jpgPES_2018-11-10_10-21-00_24mm_ by merco_61, on Flickr
Fitting the wiring before soldering things.
45766623292_340d6060be_o.jpgPES_2018-11-10_12-45-55_24mm_ by merco_61, on Flickr
The pickups in place waiting to be soldered to the controls.
43999308830_e511029903_o.jpgPES_2018-11-10_12-46-43_24mm_ by merco_61, on Flickr
The guitar is finished now, but I haven't shot the finished instrument yet... I still have the intonation to get right and a slight 50-Hz buzz that I don't know if it is a bad ground somewhere or insufficient shielding.
nbanjogal
nbanjogal
  • 2,094 posts
  • LocationUT, USA
Well, we'll look forward to seeing a glamour shot of the finished instrument!
I think of lots of p-words as I'm scrolling through this series...precision, perfection, patience, persistence...
#17
Not a glamour shot, but a presentation of the guitar.
45888972832_1b7f42e371_o.jpgPES_2018-11-18_14-35-38_46mm_ by merco_61, on Flickr
30999560487_6f69c69293_o.jpgPES_2018-11-18_14-36-40_46mm_ by merco_61, on Flickr
45888969092_7c5e08dd97_o.jpgPES_2018-11-18_14-37-22_25mm_ by merco_61, on Flickr
30999555787_e113282d64_o.jpgPES_2018-11-18_14-37-38_25mm_ by merco_61, on Flickr
45888963022_03258ee70e_o.jpgPES_2018-11-18_14-37-55_24mm_ by merco_61, on Flickr
30999551397_0449df1208_o.jpgPES_2018-11-18_14-38-14_50mm_A by merco_61, on Flickr
45938360951_45a1c91c2a_o.jpgPES_2018-11-18_14-39-03_50mm_ by merco_61, on Flickr
#18
How did you solve the harmonics issues with
these primitive bridge's saddles, buddy?   :blink:
#19
As usual on a standard Telecaster bridge... By splitting the difference, not going for perfect intonation and bending slightly when playing higher than the 18:th or so.
I am a bit surprised that I got it as close as I did, to be honest.
