Swedish Armed Forces Air Show 2018
10 replies to this topic
  • 10,635 posts
In this first post, we have an aerobatic glider, a T6 Harvard with markings from F5 at Ljungbyhed and a modern aerobatic Sukhoi Su-29.
43379383735_df99ce77dc_o.jpgPES_2018-08-25_09-28-30_600mm_B by merco_61, on Flickr
Model: NIKON D700
Lens (mm): 600 (150-600)
ISO: 640
Aperture: 29
Shutter: 1/80
42477494730_911d820e56_o.jpgPES_2018-08-25_09-30-42_185mm_B by merco_61, on Flickr
Model: NIKON D700
Lens (mm): 185 (150-600)
ISO: 1250
Aperture: 18
Shutter: 1/400
43568413834_58b04efa3e_o.jpgPES_2018-08-25_09-31-06_230mm_A by merco_61, on Flickr
Model: NIKON D700
Lens (mm): 230 (150-600)
ISO: 1250
Aperture: 18
Shutter: 1/400
43568412044_744fab0cb8_o.jpgPES_2018-08-25_09-33-15_300mm_A by merco_61, on Flickr
Model: NIKON D7200
Lens (mm): 300 (70-300)
ISO: 1000
Aperture: 8
Shutter: 1/8000
42477488950_828acc0b4c_o.jpgPES_2018-08-25_09-33-22_70mm_A by merco_61, on Flickr
Model: NIKON D7200
Lens (mm): 70 (70-300)
ISO: 1000
Aperture: 8
Shutter: 1/8000
30418413218_8b23866f53_o.jpgPES_2018-08-25_09-33-45_250mm_ by merco_61, on Flickr
Model: NIKON D7200
Lens (mm): 250 (70-300)
ISO: 1000
Aperture: 8
Shutter: 1/8000
42477478760_21f745e924_o.jpgPES_2018-08-25_09-33-46_250mm_ by merco_61, on Flickr
Model: NIKON D7200
ISO: 1000
Aperture: 8
Shutter: 1/8000
43379354275_0a3ea28292_o.jpgPES_2018-08-25_09-39-06_360mm_A by merco_61, on Flickr
Model: NIKON D700
Lens (mm): 360 (150-600)
ISO: 200
Aperture: 18
Shutter: 1/80
43379352185_421f208530_o.jpgPES_2018-08-25_09-40-03_600mm_ by merco_61, on Flickr
Model: NIKON D700
ISO: 200
Aperture: 16
Shutter: 1/80
43379360275_10eef92347_o.jpgPES_2018-08-25_09-40-07_600mm_B by merco_61, on Flickr
Model: NIKON D700
ISO: 200
Aperture: 22
Shutter: 1/80
42477474450_e07f79c2dc_o.jpgPES_2018-08-25_09-41-26_600mm_A by merco_61, on Flickr
Model: NIKON D700
ISO: 200
Aperture: 22
Shutter: 1/80
42477473730_1db08bef16_o.jpgPES_2018-08-25_09-42-12_270mm_A by merco_61, on Flickr
Model: NIKON D700
Lens (mm): 270 (150-600)
ISO: 200
Aperture: 25
Shutter: 1/80
42477473340_f01233048e_o.jpgPES_2018-08-25_09-42-22_250mm_A by merco_61, on Flickr
Model: NIKON D700
Lens (mm): 250 (150-600)
ISO: 200
Aperture: 18
Shutter: 1/80
43379358495_c20e489d55_o.jpgPES_2018-08-25_09-43-30_320mm_ by merco_61, on Flickr
Model: NIKON D700
Lens (mm): 320 (150-600)
ISO: 200
Aperture: 18
Shutter: 1/80
42477472670_a91788da94_o.jpgPES_2018-08-25_09-47-27_600mm_A by merco_61, on Flickr
Model: NIKON D700
ISO: 200
Aperture: 18
Shutter: 1/80
43568388214_8d0f9b67f7_o.jpgPES_2018-08-25_09-57-55_600mm_ by merco_61, on Flickr
Model: NIKON D700
ISO: 200
Aperture: 13
Shutter: 1/250
42477470260_0747c0a0f8_o.jpgPES_2018-08-25_09-57-58_600mm_ by merco_61, on Flickr
Model: NIKON D700
ISO: 200
Aperture: 13
Shutter: 1/250
More to follow...
sunshine
sunshine
  • 292 posts
  • LocationVirginia
Peter - I see you're using two cameras here.  Do you use a monopod with either or are these all handheld?  Would an ND filter help to keep the aperture larger?  I see a lot of dust spots, which you educated me on awhile back.  I purchased a 10 stop ND for my big zoom thinking it would help when I'm attempting low shutter speed panning but it was too dark for my last outing.  In fact, it now looks like it may be too dark for any conditions unless I'm using a tripod.  If you were going to use one in the conditions shown here, which would you choose?
  • 10,635 posts
All handheld.
I should have cleaned the sensor and had planned to do so, but other things had higher priority at the end of the week.
When it comes to what ND to use, every stop halves the light. Going to bigger apertures from f/22, the first stop takes us to f/16, the next to f/11, the next to f/8, the next to f/5.6, the next to f/4, the next to f/2.8, the next to f/2, the next to f/1.4, the next to f/1 and the next to f/0.7 for a full 10-stop series. Using this ladder makes it easier to select what strength of ND is needed. This means that I could have maintained the 1/80 shutter speed for the Harvard but @f/8-11 using a 2-3 stop ND.
sunshine
sunshine
  • 292 posts
  • LocationVirginia
When I have tried 1/30" and lower in shutter priority in the past, even with ISO dialed down to the "low 1" setting, I get apertures of f/32 which makes even the slightest dust spot appear black and pronounced.  I guess I need a full set of ND filters for brighter/darker days.  One day I want to be able to get images like yours, and like these:
https://fireproof-cr...ges/i-Lcg2KKW/A
2018 Galleries – Rich Webb Motorsport Photography
  • 10,635 posts
Here are some more: Parachute, Hercules, ambulance helicopter and JAS 39 Gripen. The reason for the D300 for the parachute soldier is that I needed the reach while they were still high up and didn't have the time to change body as they got lower. This turned out better than the ones at higher altitude.
43379357265_405303234f_o.jpgPES_2018-08-25_10-09-33_220mm_ by merco_61, on Flickr
Model: NIKON D300
Lens (mm): 220 (150-600)
ISO: 200
Aperture: 14
Shutter: 1/250
44213453672_e0fdb2b2cd_o.jpgPES_2018-08-25_10-12-35_230mm_C by merco_61, on Flickr
Model: NIKON D700
ISO: 200
Aperture: 14
Shutter: 1/125
30418391188_64f2cb5c6f_o.jpgPES_2018-08-25_10-16-19_340mm_ by merco_61, on Flickr
Model: NIKON D700
Lens (mm): 340 (150-600)
ISO: 200
Aperture: 14
Shutter: 1/125
43568379664_a0b9eca89a_o.jpgPES_2018-08-25_10-16-25_370mm_A by merco_61, on Flickr
Model: NIKON D700
Lens (mm): 370 (150-600)
ISO: 200
Aperture: 14
Shutter: 1/125
43568378004_cf91c95c09_o.jpgPES_2018-08-25_10-19-25_240mm_ by merco_61, on Flickr
Model: NIKON D700
Lens (mm): 240 (150-600)
ISO: 200
Aperture: 16
Shutter: 1/60
43379320155_efcae6d078_o.jpgPES_2018-08-25_10-20-02_220mm_ by merco_61, on Flickr
Model: NIKON D700
Serial #:
Firmware: Capture NX-D 1.4.3 M
Frame #: 1873
Lens (mm): 220
ISO: 200
Aperture: 16
Shutter: 1/60
43568371944_ba56a3e641_o.jpgPES_2018-08-25_10-22-25_480mm_ by merco_61, on Flickr
Model: NIKON D700
Lens (mm): 480 (150-600)
ISO: 200
Aperture: 18
Shutter: 1/60
42477460620_fcc2269b1f_o.jpgPES_2018-08-25_10-25-24_300mm_A by merco_61, on Flickr
Model: NIKON D700
Lens (mm): 300 (150-600)
ISO: 200
Aperture: 20
Shutter: 1/100
43379307415_c1e03bcc96_o.jpgPES_2018-08-25_10-39-04_300mm_ by merco_61, on Flickr
Model: NIKON D700
ISO: 320
Aperture: 5.6
Shutter: 1/1250
42477459370_21666ab102_o.jpgPES_2018-08-25_10-48-18_300mm_A by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 11
Shutter: 1/640
42477456530_b397737260_o.jpgPES_2018-08-25_10-48-37_440mm_ by merco_61, on Flickr
Model: NIKON D700
Lens (mm): 440 (150-600)
ISO: 500
Aperture: 9
Shutter: 1/640
44285842091_6ea354a11f_o.jpgPES_2018-08-25_11-15-25_380mm_A by merco_61, on Flickr
Model: NIKON D700
Lens (mm): 380 (150-600)
ISO: 500
Aperture: 16
Shutter: 1/640
43568355684_fbabc06cb1_o.jpgPES_2018-08-25_11-16-40_450mm_ by merco_61, on Flickr
Model: NIKON D700
Lens (mm): 450 (150-600)
ISO: 500
Aperture: 20
Shutter: 1/1000
30418359878_dfbcd10bc7_o.jpgPES_2018-08-25_11-20-08_360mm_D by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 13
Shutter: 1/1000
29326115427_3d8795117b_o.jpgPES_2018-08-25_11-25-07_190mm_ by merco_61, on Flickr
Model: NIKON D700
Lens (mm): 190 (150-600)
ISO: 500
Aperture: 13
Shutter: 1/1000
There will be a third post, but the forum software will just append it to this one if I try to post it immediately.
I really enjoyed the gliders… cool!   :P
  • 10,635 posts
The third and last instalment are: J32 Lansen, J35 Draken, a Danish F16 Fighting Falcon, a helicopter and J34 Hawker Hunter.
29349628117_cb1d138e78_o.jpgPES_2018-08-25_12-01-06_600mm_ by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 8
Shutter: 1/1250
30418356478_88b7fc236c_o.jpgPES_2018-08-25_12-02-20_600mm_C by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 10
Shutter: 1/1250
42477435540_cbf9e57c57_o.jpgPES_2018-08-25_12-04-31_600mm_ by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 7.1
Shutter: 1/1250
42477434260_7482d93d80_o.jpgPES_2018-08-25_12-09-38_600mm_ by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 11
Shutter: 1/640
43379284595_f6e3d73781_o.jpgPES_2018-08-25_12-09-47_600mm_ by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 11
Shutter: 1/640
44213451132_98919be013_o.jpgPES_2018-08-25_12-12-13_600mm_E by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 8
Shutter: 1/640
42477429680_f0fc574774_o.jpgPES_2018-08-25_12-13-06_600mm_A by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 11
Shutter: 1/640
43356222415_893a79004e_o.jpgPES_2018-08-25_12-13-50_600mm_A by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 11
Shutter: 1/640
43379279475_16079676d0_o.jpgPES_2018-08-25_12-22-32_600mm_ by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 6.3
Shutter: 1/640
44285825801_25a7c30587_o.jpgPES_2018-08-25_12-22-33_600mm_ by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 6.3
Shutter: 1/640
44237259632_a59857ce15_o.jpgPES_2018-08-25_12-22-39_600mm_ by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 9
Shutter: 1/640
43568331744_e9d3ca10a6_o.jpgPES_2018-08-25_12-22-45_290mm_ by merco_61, on Flickr
Model: NIKON D700
Lens (mm): 290 (150-600)
ISO: 500
Aperture: 11
Shutter: 1/640
43568324704_e4fbc80afb_o.jpgPES_2018-08-25_12-23-07_600mm_A by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 18
Shutter: 1/640
43379260225_93eb1b6920_o.jpgPES_2018-08-25_12-23-45_600mm_ by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 16
Shutter: 1/640
43379258215_837e6682a4_o.jpgPES_2018-08-25_12-24-19_600mm_D by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 11
Shutter: 1/640
44285802671_76474aec75_o.jpgPES_2018-08-25_12-26-31_600mm_ by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 16
Shutter: 1/640
44285800721_4f7d59dace_o.jpgPES_2018-08-25_12-35-40_330mm_B by merco_61, on Flickr
Model: NIKON D700
Lens (mm): 330 (150-600)
ISO: 500
Aperture: 29
Shutter: 1/80
44285799081_1faf46eb20_o.jpgPES_2018-08-25_12-42-53_600mm_B by merco_61, on Flickr
Model: NIKON D700
Lens (mm): 600 /150-600)
ISO: 500
Aperture: 6.3
Shutter: 1/1250
44285796211_2578e812e0_o.jpgPES_2018-08-25_12-43-58_600mm_ by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 9
Shutter: 1/1250
44285793771_b57c8725e2_o.jpgPES_2018-08-25_12-44-01_600mm_A by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 9
Shutter: 1/1250
44285791771_60316a56f4_o.jpgPES_2018-08-25_12-45-30_600mm_A by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 7.1
Shutter: 1/1250
44285790411_ab1b710da1_o.jpgPES_2018-08-25_12-52-20_600mm_A by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 6.3
Shutter: 1/1250
44285786001_b5a9e75e8d_o.jpgPES_2018-08-25_12-52-30_330mm_ by merco_61, on Flickr
Model: NIKON D700
ISO: 500
Aperture: 7.1
Shutter: 1/1250
Some of these need the horizon straightened as my left arm was getting a bit tired by now. I will get around to it for prints, but they will do for the web. The only adjustments I have done in post are some crops and some retouched spots.
Nice set of nice sets Peter!  Looks like it was an enjoyable show!  Thanks for sharing!
nbanjogal
nbanjogal
  • 2,094 posts
  • LocationUT, USA
Really amazing sets, Peter. I am blown away by the clarity you're getting with that 150-600mm HANDHELD!!! What the heck?! Ok, was PES_2018-08-25_09-57-55_600mm the aerobatic plane, and was it shot while upside down in the air? The first time I looked at it, I thought you must have caught a ride in one of the planes and somehow got above it.
I think my favorite of all of these is the Hercules dropping its load--that is a storytelling shot right there, and you caught the perfect moment. Such impressive work.
  • 10,635 posts
Thank you Nicole.
The shot you mentioned was shot at the entry point of a tunnel roll. If you look at the shadow of the elevator and the shadow from the wing on the wheel fairing, you will see what the orientation was relative to the sun.
The transport division from F7 always have a narrative to their show with the C-130. This year the theme was dropping, supplying and picking up paratroopers.
snell
snell
  • 73 posts
  • LocationSouthern New Jersey
Thanks for sharing Peter, they are impressive shots!
