Intermittent Blacking Out With NIKKOR 32mm f/1.2 Lens
nikkor nikon 1 32 mm 32mm f/1.2 lens
6 replies to this topic
aimeek
aimeek
  • 4 posts
Hi,
I'm using a Nikon 1 camera with a NIKKOR 32mm f/1.2 Lens.  The problem is that when I'm trying to focus, the camera keeps blacking out on and off with this lens.  The viewfinder goes all black for under a second each time.  If I take a picture during the blackout time, it does save a photo that is all black.  When I replace the lens with my Nikkor 6.7-1.3mm lens, the blacking out does not happen.
Can anyone please help me fix the problem?  I appreciate any advice!
Here is some information about NIKKOR 32mm f/1.2 Lens from the website:
The black Nikon 1 NIKKOR 32mm f/1.2 Lens is a fast medium telephoto-length prime lens designed for use with the Nikon 1 series of mirrorless digital cameras. The 32mm focal length is equivalent to 86.4mm in the 35mm format, and coupled with the maximum f/1.2 aperture renders this lens ideal for portraiture due to its longer-than-normal perspective and ability to produce imagery with a shallow depth of field. Also contributing to offering greater control over focus placement is the inclusion of a manual focus ring, which can be used in both manual and auto focusing modes due to the M/A manual focus override capability. When working in autofocus modes, a Silent Wave Motor (SWM) focusing mechanism provides smooth, fast, and quiet focusing performance that is ideal for use when recording HD video.
-Aimee
Fletch
Fletch
  • 404 posts
  • LocationHawaii
Just a guess but if everything works with other lens this lens may have dirty contacts or something worse. Using a soft eraser gently clean the contacts on the back of the lens.  Don't over do it or scrub real hard.
  • 10,635 posts
Another, potentially safer, method of cleaning contacts is using De-oxit gold. This removes oxide from the contacts and leaves a residue that aids electric contact and prevents new oxide from forming for a while.
Fletch
Fletch
  • 404 posts
  • LocationHawaii
De-oxit gold
Thanks for that info, going to have to see if my local camera shop carries it.
aimeek
aimeek
  • 4 posts
Thanks, I also noticed that it only happens at lower ISO.
  • 10,635 posts
I think you will have better luck at an electronics or hifi shop. Radioshack carried it.
mayra
mayra
Hi,
-Aimee
Hi Aimee,...same problem with the same Lens...how did you finally fix it??
Cheers!
Also tagged with one or more of these keywords: nikkor, nikon 1, 32 mm, 32mm, f/1.2 lens
