I recently purchased the above referenced lens on the cheap. Yes, I was aware of the existing problems prior to purchasing.
So, here is what I have. The auto-focus works only occasionally and not more than one shot. The Manual Focus is stiff on the second half of the travel range. It is easier to rotate the Manual focus ring when the lens is not mounted to my D200. When on the camera, it makes a grinding noise when the Manual Focus Ring is turned. What is so puzzling is that the lens truly is in pristine condition appearance wise. The push/pull mechanism ring is also in like new condition. The glass is in perfect shape, no fungus, oil or haze anywhere. In Manual Focus, the lens takes wonderful photos. The only thing that makes any sense is that someone took it apart and messed up when re-assembling the lens. Once again, there isn't one dent, scratch or surface wear on this lens. Yes, I did check into getting it repaired and it would be more cost effective to purchase another one say from Amazon.com or even ebay. When I spoke with the seller he was honest and upfront about everything. He did say that the lens is damaged, however there is not even a slight indication of any type of physical damage. Also, the numbering and lettering show no signs of wear at all. Appearance wise, this unit looks in better shape than some of the new or even newer copies. Go figure.
Forgot to mention that the lens aperture ring turns with no problems.
Many thanks for any suggestions/solutions.
Tony
