So I just snagged a couple of monolights that use this mount for light modifiers. I'd like to build a couple of my own modifiers so I am trying to source some "empty" bases to use as the starting point.
But to my surprise, the internet has let me down. Anyone know where I can get some of these (preferably in the States)?
Bowens S mount bases...
Started by ScottinPollock, Aug 10 2018 12:05 PM
Posted 10 August 2018 - 12:05 PM
Posted 10 August 2018 - 12:51 PM
Is the Phottix S-mount speedring a good enough base for you to build on?
https://www.bhphotov...for_bowens.html
If you search for S-mount speedrings, you will find something that works as a base for DIY modifiers. The cheap ones will probably need modification unless you design the modifier around whatever their engineers have created.
- TBonz and ScottinPollock like this
Posted 10 August 2018 - 02:19 PM
Ahhh... speedring was the term I was missing. The one you linked to is overkill, and ideally I'd like a plastic one to make fabrication easier. I'll keep searching.
Thanks!
