significant different exposure between D610 and D750 with off camera flash
d610 d750
stevenjose
stevenjose
Hi,
Here is my problem, thank you in advance,
- I have a controlled environment where the light is not changing,
- I have the same settings between a D610 and D750 as shown in images below
- both have Nikon 50mm 1.8g attached
- i am using  the same Neewer Speedlite 750ii on both cameras (no settings are adjusted on this flash between changing camera)
- speedlite flash settings are TTL, +3
- A tripod is used so the camera potions are identical
- there two other lights which are set as slaves, so are triggered when the speed light goes off
- I have removed the speedlite from the camera and carried out the same experiment, the images appear to be identical when no flash is used, this is making me think its a flash issue
Both camera flashes seem to be of the same power when observing by eye
I have no idea what this may be, could someone please help,
Thanks again,
Steven
  • 2,255 posts
No clue... unless the difference is between the EXPEED 3 software in the D610 and the EXPEED 4 software in the D750.
  • 648 posts
It's probably an issue with the ttl compatibility of the flash. Try it on manual.
Also tagged with one or more of these keywords: d610, d750
