Manual Focus With Live View
Posted 15 July 2018 - 07:30 AM
I’m trying to learn how to use my camera in A..S..or M, when I take shots through eye piece my pics are never focused. I have tried adjusting the +. - with no joy, maybe as I wear glasses?
If I use live view there good but when sunny I can’t see view finder as too bright. Can anyone tell me how they do it.
Regards
Posted 15 July 2018 - 12:07 PM
As regards the dioptric correction, there are two ways of working:
- keep your glasses on (ok, they get dirty after a while) and use the neutral setting (the correction is done by your glasses) while using the viewfinder - this is the way I work
- remove the glasses, use autofocus and then start adjusting the dioptric setting until you see a sharp picture to find the good setting (basically the same than adjustging binoculars)
If you can’t get the pictures to become sharp while autofocussing there might be other (technical) issues - but this seemed not to be your point.
HTH
Posted 15 July 2018 - 01:21 PM
Oh I have a D5200.
Thanks Again.
Posted 16 July 2018 - 06:58 AM
I have checked on a D5100 which I had at hand and for that camera there was no issue for selecting the MF. Also having checked the D5200 User manual (page number 30 of file http://download.niko...D5200VRUM_EU(En)01.pdf ) and there is no mention for it not being available. Are the other AF-S, AF-A, AF-C modes available?
What lens is connected - and does that lens usually works fine?
TBH I don’t know what could cause the MF not being available, while other modes would be.
- Den61 likes this
Posted 16 July 2018 - 08:16 AM
when I press info button to set iso etc the “MF” manual is never highlighted
If the Focus Mode setting in the Info display reads MF and is not selectable, the camera thinks it can't autofocus. This could be due to:
- Physical A/M switch on the lens is set to M.
- Dirty lens contacts.
- Incompatible lens (screw drive autofocus is unsupported on 3000/5000 series).
- Malfunctioning lens or camera.
- Manual focus lens.
Posted 16 July 2018 - 09:39 AM
we should be able to provide "next steps" in trying to figure out your issue...
LOL... I am not even sure what the issue is. The thread title is "manual focus in live view", and he goes on to say he is having no luck with it using the viewfinder. Not surprising as I find MF using the 3000/5000 series' puny dark viewfinder near impossible for manual focus. Even the prism based VFs are iffy since we no longer have the split-prism aids we had in the film days (big reason I bought a mirrorless).
But then he goes on to mention he is using the electronic rangefinder to set manual focus and still having no luck. That should be pretty accurate if he has the right focus point selected.
So it is kinda like one of those support questions "it doesn't work". How does it not work? Exactly what are you doing to try and get it to work, and what is the unexpected behavior you are experiencing?
@Den61 How about posting a couple of your mis-focused photos, what part of the frame you were trying to focus on, and what focus point was selected, and your EXIF info?
- Den61 likes this
Posted 16 July 2018 - 10:26 AM
Posted 16 July 2018 - 11:08 AM
If I switch from MF to AF on lens it highlights?
Expected behavior. If you switch the lens to MF, the camera can't autofocus so the in-camera setting for MF/AF is disabled.
Posted 16 July 2018 - 12:36 PM
Right got it. Cheers
Posted 03 July 2019 - 07:52 AM
I need help with the Manual Settings on the D5200. Is there any information on this?
