Please Critruque and help
14 replies to this topic
Steve M
Steve M
  • 238 posts
  • LocationSE Minnesota
I took this photo along with many others. I am still a newbie but I thought this was a good photo. The eyes are very crisp but I was told it was a very poor photo. Yes I was hurt as I was told I either have a bad camera or I don’t know what I am doing. The grass and many areas are out of focus. And they are right.
The photo
2500 Shutter Speed. Yes a bit high but was taking fast moving trains before. Plus since they are hitting me with Chemo (everything will be fine just a bit of a rough road) I have issues with shaking but I do try and rest the camera on something.
D7200
Manual Mode
Aperture is 10
ISO is Automatic
AFC WITH 9 points and single point metering.
8559_FBD9-_B758-44_E4-_A610-6_B925_F1_C6
Now I found a similar place since this place was far away and changed the Aperture to 20 leaving all the rest the same. Again the background is the same.
7_F886628-_A789-4588-_A4_B4-_D37_DD2_BA5
Also I took out my old D40x and I get the same results.
So anyway I would appreciate any help or advice.
  • 648 posts
I don't think this is a bad shot (short of the harsh light). You shot it at 370mm... even at f32 you won't get the background sharp. The more the focal length/magnification, the shallower the depth of field.
For me, having a sharp, contrasty, busy background is a huge distraction. I would have opened the aperture for a nice, soft blur to the background that would make the bird stand out.
Note that the below is a really rough composite to demonstrate what I would have gone for.
Malice
Malice
  • 212 posts
You shouldn't take everything to heart that you are told.
This is a good photo. Okay, maybe it's not perfect, but it's far from bad.
When taking photos of individual subjects like this bird here, it is very often a wanted technique to separate the subject in the foreground from the background by having the latter out of focus. I.e. this is often done on purpose. There's nothing wrong with that. Rather to the contrary.
As has been mentioned by ScottinPollock already.
Colin B
Colin B
  • 56 posts
  • LocationPerth Western SAustralia
Well, all I can say is "I wish I had taken that shot".
Yes, a cleaner background, or one blurred into insignificance would be nice but it is not as if you could say "Hey, birdie, just step over here into this open patch of ground away from that clutter.... :P " Too much fluffing around with the camera or shifting positions and all you get is a flap of wings and a missed opportunity, especially with these guys as Egrets are very wary birds.
The only thing I would change is to go back in my time machine and let the bird take one more step past that whitish log(?) behind its head but a bit of fiddly work in Photoshop could fix that.
  • 10,589 posts
That is definitely not a poor photo. It is not the best it could be, but far from poor.
Those who want more in focus are used to bridge cameras where the small magnification due to the small sensor makes nearly everything look acceptably sharp, until you take a closer look and find that everything is slightly mushy and then oversharpened to compensate. This is a much better photo.
You would probably have got even more impact from the selective focus if you had closed the aperture down less, to f/6.3 or 7.1 rather than 10 to get better separation between background and subject. A good sample of the 80-400 is sharp enough that 1/3 step closed down is enough even at the long end.
The other two factors that make this far from ideal are out of your control as you can't tell wild birds to move a bit or to come back when the light is better.
Steve M
Steve M
  • 238 posts
Thanks everyone. These Egrets are very skittish. Outside of a vehicle you can’t get close. I drove along the highway slow but once my camera comes out the window they are off.
Again thank you for all your comments. I really appreciate it.
leighgion
leighgion
  • 167 posts
  • LocationMadrid
Totally not a poor photo.
I don't know who made the comments, but I'm going to be direct and say complaining that the background isn't in focus, especially for a shot of this nature, is straight up stupid. I know it can be very tempting as a neophyte photographer to pick certain technical aspects and use it as "objective" standard of quality, but that's just lying to yourself.
As other posters have noted, not only a soft background not in any way an indicator of "badness," in cases like this shot, an even softer background would have been an aesthetic benefit.
nbanjogal
nbanjogal
  • 2,094 posts
  • LocationUT, USA
I'll just add my +1. I agree with everyone else. Not a poor photo. At all. As has already been mentioned several times, you don't WANT a sharp, busy background. You want to isolate your subject, and having a soft, blurry background is a really good way to do that (it's called "bokeh," and photographers who know what they're doing use it all the time). ScottinPollock's example is just what I'd go for as well. So, my friend, I would actually say that whoever gave you those comments is the one who doesn't know what he is doing. Take the comments with a grain of salt.
And hey, I hope your health is ok. Good luck with the chemo. I know that's not a pleasant process.
sunshine
sunshine
  • 292 posts
  • LocationVirginia
Steve - I'm with everyone else here.  That's a good shot.  If you look at very much wildlife imagery you will quickly see that blurred, unrecognizable background is preferred.  As has been stated above, a wider aperture could have provided more bokeh, and morning or evening sunlight might have improved the overall look, but it's still a good shot.  Take a look at Steve Perry's "Backcountry Gallery" for examples.
Here's one I got this weekend.  Your original critic would probably think this is an awful photo, too.  I like them both - mine and yours.  Mine looks a little dark, and I haven't had a chance to work on it with Lightroom yet.  (I'm limited to Apple Photos on my company macbook until I get home.)  But there's certainly nothing wrong about yours.
dinner by Mark, on Flickr
Steve M
Steve M
  • 238 posts
Thank you so much.
Steve M
Steve M
  • 238 posts
I was able to get out yesterday and go back to look for the Egret. I did find him but also found a pair of Sandhill Cranes.
Little editing just from my iPad
SS 2000 Aperture 5.6
85752884-5_B0_E-4_D65-_B053-6_BA287_F384
Aperture at 13 just for kicks
2818_AABA-0348-4_F06-_A4_A0-_B92_F2_C822
Aperture 5.6
8_B90_B1_C3-_B04_E-4_ACC-_ADAD-7_A95470_
leighgion
leighgion
  • 167 posts
  • LocationMadrid
You notice that your last shot looks especially good because most of the background is water, making it very smooth.
If you want to use this as an opportunity to deepen your understanding of depth of field and quality of bokeh/out of focus areas, you could consider the technical characteristics of the out of focus trees in the background of the other shots. They're soft, but not as smooth as they could be, which is a characteristic of the lens that isn't in your control. When people get deep into this subject, lenses get judged on the quality of their out-of-focus rendering, aka "good" and "bad" bokeh.
Couple examples following the bird theme:
1466347018_ee7bc5ead2_z.jpg?zz=1
Fishing in the Shallows by Leigh, on Flickr
The 500mm mirror lens, renders tiny doughnuts of light due to its particular design.
Eavesdropping Robin by Leigh, on Flickr
70-200mm f/2.8 renders much smoother.
mikew
mikew
  • 798 posts
  • LocationNorth East Lincs
You have been told a load of crap about the first image,yes it could be improved but as you say you are learning, out of focus back grounds are just what you want for most wildlife shots, perhaps the person who said these things needs to learn about depth of field and the fact you used it correctly.
  • 1,098 posts
all your pictures look good. since out focus spots are out focus and spot need to be in focus are but few area will be hit and miss since subject will grab the ground with subject too.
Hey Steve,
the key word here is background separation!
This may be achieve in mainly three ways:
  1. chrominance separation
  2. luminance separation and
  3. focus (includes detail) separation
Here, the third point would work best in this scene. The problem
is your chosen aperture: ƒ 10 was not the right choice as a much
bigger on would have nailed it.
All the best!  :P
