Nikon d750 obstruction?
Posted 14 April 2018 - 09:33 AM
Posted 16 April 2018 - 11:51 PM
You see the black block only on the rear screen - not while looking through the viewfinder? Correct?
I don’t think it has to do with the lens, but rather with the screen (or the electronics or cables that send signals to the screen).
As the rear screen of the D750 can be flipped, you might move it to see if there is a bad contact. (Not as matter of fixing, but as a matter of identifying a possible issue)
If this confirms and it is under warranty I’d suggest to return it. If you got it second hand, see with the seller.
Posted 26 April 2018 - 05:13 PM
Hi,
I have this exact same issue with the exact same lens. I've owned both for just over a month. Everything has been working smoothly and then all of a sudden today I turn it on and a) autofocus isn't working and the images taken show this black square covering the bottom 3/4 of the image whether I shoot through the viewfinder or using the back panel. Hopefully, someone can shed some light on this issue?
Posted 30 April 2018 - 04:30 AM
Hi,
Could you share a sample that shows the problem?
Posted 30 April 2018 - 07:58 AM
Examples AND Details...EXIF information and anything else you can tell us about the shot or shots you provide as examples...
Those things can all contribute to our best being able to help you!
Posted 28 October 2020 - 02:26 PM
Hi,
Hey!! My Nikon D750 just started doing the same, any idea what happened to yours? How did you fixed it?
