What would be the best settings for the D850 to exploit Infrared filters (Hoya 77mm R72 Infrared Filter) and have effects of white trees ? In other words does this camera provide any advantages to make this kind of infrared pictures?
Best settings of D850 for infrared photography
Posted 01 April 2018 - 02:26 PM
Posted 03 April 2018 - 12:40 PM
AFAIK, the D850 continues the progression of better and better cutoff filters to eliminate IR blooming. The newer the body, the worse it is as a candidate for invisible light captures without modifying the filter pack on the sensor.
Posted 04 April 2018 - 01:10 PM
Peter is right. Newer cameras aren't usually good candidates for shooting IR without modification. And, the mods will void your warranty (if that's important to you).
Most of the people who shoot a lot of IR tell me that they've purchased a used body and had that modified by removing the cutoff filter from in front of the imaging sensor and had it replaced with a special filter that passes mostly or only IR light. This allows them to view and focus through the viewfinder as though there were no IR filter mounted at all.
On the other hand, you can sometimes simulate the IR look in post (with varying amounts of success).
Posted 04 April 2018 - 02:41 PM
The filter will only let pass light of a limited frequency, so if the filter only lets pass infrared but the filter on the sensor blocks in a second step this extra light the result will be a black picture.
Some years ago a forum member (I think it was @Thumper) has posted some captures of « infrared » pictures taken with filters - if I remember fine he mentioned that using the filters was having some manipulations required as they blocked most of the light (thereby requiring to frame and focus before mounting the infrared filter) - similar to strong ND filters.
When I investigated in infrared capturing, I bought a used D90 with a modified sensor - this allows to give real interesting captures. Here are a few taken with that camera
Also tagged with one or more of these keywords: d850, infrared, special effects
Nikon Cameras →
Nikon FX DSLRs →
issues cleaning d850 sensorStarted by owenpga, 22 Feb 2024 sensor cleaning, d850 |
Camera and Photo Help →
Technical Troubleshooting →
D850 taking extremely dark photosStarted by JayDee, 21 Feb 2024 d850 |
Infrared IR not working all of a sudden on a Nikon D750Started by redgilda, 22 Mar 2023 ir, infrared, d750 |
Beginner Questions →
ConfusionStarted by 8men, 31 Dec 2022 d850, sb5000 wireless remote |
Mirrorless v DSLRStarted by Seabass, 08 Jun 2021 mirrorless, d850, battery life and 1 more... |
