Nikon Df initial shutter count
9 replies to this topic
Darren@RI
Darren@RI
Hi All,
I just received my Nikon Df (black with the 50 1.8 kit) this morning. Yay !
Everything else I have uses the EN-EL3 or 15 so I had the oh so long (not really) wait for the EN-EL14a to charge .. ramping up the anticipation ! :D
Looking at my first handful of test shots in Photo Mechanic and being very pleased, I did spot that my first shot had a shutter count of 227 in the metadata. With my previous Nikon DSLRs that piece of metadata was either 0 or very low (maybe a couple of flips of the mirror into Live View and back). Did anyone see the same ?
I am hoping its just some factory testing or something rather than me getting a return ... if that is even possible when the critter was only release early in the week ! I really like the camera a lot.
All that aside, I am very pleased with the camera so far - the image quality is great. I look forward to rambling on about that later ... :-)
D.
K-9
K-9
    Jamie
  • 883 posts
  • LocationNew England
I wouldn't worry about the shutter count if the camera looked untouched when you unboxed it. I've heard of new bodies with counts in the hundreds before.
Darren@RI
Darren@RI
Thanks K-9 - much appreciated !
The first image was actually called DSC_0001.JPG, which backs up what you are saying. I guess I was just lucky in the past.
So ... for the first time ever I got to use my olde Micro-Nikkor 55mm f/3.5 P.C. on a Nikon full frame camera. Previously I had only used it on my D40 or my 5D Mk II with a novoflex adaptor. Yay !
Tony892
Tony892
    Tony892
  • 1,006 posts
  • LocationRingwood, Hampshire, England
I have not heard the term 'shutter count' before, can you explain background on this?
  • 4,794 posts
The number of exposures the shutter has fired is hidden in the EXIF information. Unlike the file numbering this is not resettable.
It can be read in photo mechanic directly, or in Photoshop by opening a raw file and look in "File info" under "file". Choose Advanced and expand "ns.adobe.com/exif/1.0/aux/." Read the number in "aux:ImageNumber: xxxx."
K-9
K-9
    Jamie
  • 883 posts
It's how many times your camera's shutter has been pressed, or how many times your mirror has flipped open to take a photo.
Darren@RI
Darren@RI
I don't know if a third answer is really necessary :-) But here is some more background info : How to Find Total Shutter Actuations on Nikon and Canon DSLRs
scoobymax
scoobymax
  • 189 posts
  • LocationDunstable, UK
Ye my new camera had a shutter count of about 100! The thing with nikon is they do such rigorous testing of their products that sometimes the shutter count can be quite high! Don't panic!! Most nikon s have a max shutter counter of 150000+ before the shutter assembly "wears out" and may need replacing but this is just a base number, I've seen shutters with 200000+ counts and still going strong!
BeerBelly
BeerBelly
  • 52 posts
  • LocationSlovenia
I've read reports on other forums that Df have quite a high initial shutter count when purchased...it could be more testing than other models since it's a new product.
Jayvee
Jayvee
  • 8 posts
I have used Opanda IExif, and it is very simple to use. Once installed and the program opened, you only need to drag your chosen jpg and drop it onto the space where it says 'Thumbnail', and to the right comes up all the exif data. Nice and quick with no messing about .....just scroll almost to the bottom and you'll finder your shutter counts.
This shows you how easy it all is  How to Count Your Shutter Actuations With Opanda iExif
OR  Opanda Exif (Nikon Users) | Ridemonkey Forums
Definitely works with my Nikon, don't know about other makes of camera, but can't see why not. What I do know is that it will display full exif details of my little Fuji compact - but no shutter count.
I downloaded the program from Opanda IExif Download
Worth having just for a quick exif check without having to load into Lightroom etc.
Recent blog entries on this topic
By Merco_61 in My musings on technique and sometimes technology, on 01 December 2013 - 02:04 PM
Source: Nikon Df initial shutter count
Read Full Entry →
